Inserting an object table
1) Is it possible to insert a table into a layout grid? If not, how can I control its location on the page?
2) How can I populate csv data into that table?
Alex
Re: Inserting an object table
1. I'm sorry this is not possible. Tables only support absolute positioning.
2. There is no standard solution for this. This requires a custom script.
OK, I found a way to do this
I would like to program an extension and share it with the group
How do I create an extension for QEWB?
You can create an extension with Extension Builder for WYSIWYG Web Builder:
https://wysiwygwebbuilder.com/extension_builder.html
(Windows only)
after building the extension you can convert the wbx file to a xmz file with this tool:
https://www.quickandeasywebbuilder.com/extensions.html
This assumes that I have a Windows machine...
Any chance that we will have the tool soon in QWE?
I'm sorry, there currently no plans to implement this tool for QWE. The number of QWE users is too small to make this profitable.
