Add icon to a button
All the buttons here are Themable buttons : http://www.nmaa-rc.org.au/rclinks21.html
Is there a way to add a logo / icon to each?
I tried adding a background image, but no go...
Re: Add icon to a button
The themeable button currently does not support icons.
But you can try to create the button with a Breadcrumb menu and a single menu item. This supports icons.
Good to know,
I have in the meantime set it up with just image - logo
