Give visitor page edit access
Re: Give visitor page edit access
Resolved, placed the data into session variables, works OK
But, would still prefer the idea of online editor
Did you configure the summernote editor in the properties of the admin object?
Did you republish all files?
Note: I cannot see what you have done based on the published page so if you need my help then please share a demo project so I can see all your settings.
I asked before - what do I write in the Editor settings
It brings up an empty popup?
Also, I see that :
1) A table can can only have 2 x 2 boxes, but I need 5 lines each with 6 columns table
2) Also, it seems I can't insert a Layout grid into the editable area, or can I?
The "Editor settings' are to set custom options for the selected editor. These are different for each editor.
The 'Editor Type" property should set to 'Summernote"
Please see (Step 2)
https://www.quickandeasywebbuilder.com/ ... ntent.html
For further detail about the editors see step 6:
https://www.quickandeasywebbuilder.com/cms_tools.html
A table can have any number of columns and rows
See my demo:
Online editors do not support layout grids. A 'layout grid' is not a HTML feature. It's specific to QWB.
I don't really care about layout grid, if I can make a table with the number of lines and columns.
I read all those documents you are pointing me to, but still can't figure out what to do in editor setup for Summernote
I read chapter 2 and chapetr 6 several times
Step 1
Place the editor files in the summernote folder on the server.
Step 2
Set editor type in Editable Content Admin to 'Summer note'
Step 3
Publish the page.
Which of these steps is unclear?
All 3 steps are clear
I did all of them as instructed
Here is an image of the folder and files : https://nmaa-rc.org.au/Summernote.jpg
This is the root folder of the site, the admin and edit files are also in that folder
But?
I think the folder name should be lowercase: summernote
OK, that fixed it - I just copied the uppercase from the Editor type in the program.
Anyway - here is the result : https://nmaa-rc.org.au/adminedit.php - password - president
As you can see the filename is memberfees.html , but - when I try to watch it is a html file,
I get this : https://nmaa-rc.org.au/memberfees.html - which is the design page in WB
So, how can I use this? I need to use the html page in the website
I'm sorry, I do not understand what you are asking.
The editor seems to work now, right?
Did you expect something else?
The editor seems to work ok, but try to view the memberfees.html after saving, you get error, no page found, just the json file is created with the changes in it that I have just saved, but where is the html file?
The page in the editor is structured inside a table with 6 columns and 5 rows.
What do you see?
Maybe, I just have to configure the editor in the admin module, but how?
Your page did work yesterday for me. I was able to edit the table and I could see the table on the memberfees.html page. Now it looks like the page has been removed.
Did you change something in the meantime?
Well, if you go through the admin and edit the page - you can see it, edit it, save it
Now, if you try to see the HTML page, you go to this link : https://nmaa-rc.org.au/memberfees.html
Correct? Now, please note - this is NOT the page you have just edited, it is what was published by me from WB, I removed it to avoid the confusion, this is NOT the page that you are editing. The page you are editing has no colours, but it has a TABLE, right?
Please understand, you are looking at TWO different things, I can't find the HTML page that is produced by the Admin editor
It seems to work correct for me, I was able to modify the content:
You must have done some magic... It works for me now.
But, the layout and font size in the editor is larger, then in the html page it is too small
Also, in the editor - I created a table so that it looks right, but in the html there is no table
How can I fix this?
Thank you
