Using PACE object
Using PACE object
I want to use this whilea submit button is clicked to indicate to the user that something is going on
But, I want the object to be hidden on page load, then show up on the button click for a time it takes to finish
Please have a look at my page sample here - the pace despite being hidden, shows up on page load and the botton doesn't do anything
https://nmaa-rc.org.au/progress.html
Re: Using PACE object
I'm sorry, I do not have a standard solution for this. The Pace extension was not designed for this.
This will require a custom script.
