Admin user edit
Admin user edit
I am using the admin object to manage the user list here:
https://nmaa-rc.org.au/adminusers.jpg
How can I replace the "Status" column with another column in the csv table?
Or, insert another column into that view?
Re: Admin user edit
I;m sorry, tHere is no option to replace column. You will have to modify the code for this yourself.
