Responsive Menu - Current page indicator
Hello,
I have two questions:
1. Is there a way to add to the Responsive Menu object an option to have some sort of indicator saying this is the current page? For example a Line under the Page name?
2. My homepage has a weird issue: https://www.couponsexplorer.com/ where on Windows - Google Chrome there is a scrolling bar in the bottom, I can not manage to discover what causing this. Do you maybe know what causing this?
My page has the following error: "Style Heading <h1> does not have the same breakpoints as the page. - Not sure what that means.
Thank you.
Re: Responsive Menu - Current page indicator
1. Did you try the option 'Highlight current page'?
This uses the hover state to indicate the current page.
2. There seem to be an issue with 'MainLayer' is looks like it's wider than the viewport.
If you need further assistance then please share a DEMO project so I can see your settings.
Thanks.
I see this feature now. But it's quite limited with the design options, could be very nice to add like Border Bottom option as an indicator of current page.
You can post suggestions here:
https://www.quickandeasywebbuilder.com/ ... m.php?f=28
If more users find this useful, then I will consider it for future development.
