Masterpage positioned differently betwee two pages
Hey,
For the header part (Logo and Main menu) I am using the same masterpage, with the same settings, as with the rest of the pages.
On page 1 - The homepage: the Masterpage content is positioned in position X.
While on page 2 - for example Categories page: The Masterpage page content is positioned in position Y.
Could you please tell me what am I doing wrong?
How to re-produce and see what I am referring to:
1. Go to https://www.couponsexplorer.com/index.php
2. At the same time open in a new tab https://www.couponsexplorer.com/categories.php
Switch between the tabs and you will see that the Logo and Main Menu are not placed on the same position.
How can I fix this? This is not causing a fluent user flow to the eye. It looks like things are changing.
Thank you.
Re: Masterpage positioned differently betwee two pages
To be able to help you, I need a DEMO project (.qwb file) so I can see all your settings.
I do not need the complete project because that will only take more time to figure out what you have done.
Basically, I just need a small project with one page and object(s) that are relevant to your question.
Note that I cannot see what you have done based on the published page (HTML), because the software has thousands of options and millions of possible combinations.
So, there is no way to know which options you have used by looking at the HTML only.
For further details about how to share a project file, please see this FAQ:
https://www.quickandeasywebbuilder.com/ ... 10&t=45024
