Inline images and separator
richotchkiss
Post by richotchkiss »
Am I missing something? I see how to insert an image or separator. But, how do you insert them so that they are in-line with the text (i.e. they move if you enter more text above)?
Thanks.
Re: Inline images and separator
By default, all objects are absolute positioned. So, an object's size and position does not affect the position of another object. This allows you to layer objects on top of each to create 'wysiwyg' layouts.
If you use flexible layout using layout grids or flexbox, then the layout will automatically adjust.
See also this tutorial:
https://quickandeasywebbuilder.com/layout_modes.html
