Cannot launch installed software
askwara
Post by askwara »
Hello,
I downloaded and installed version 9 on my Linux Mint 19.2 - I wanted to test it. It seems to be properly installed but I cannot open it. Im clicking the icon in the menu and nothing happens.
Im using QnEWB 7 on this machine, it works. Why QnEWB 9 does not?
Thanks,
Alex
Re: Cannot launch installed software
Maybe you have installed the 32bit version instead of 64bit (or vise versa)?
In the core, there is no difference between version 7 and 9, so both should work in the same computer.
