Refund Policy
PLEASE READ THESE MESSAGES IF YOU HAVE PROBLEMS WITH YOUR ORDER OR ACTIVATING THE SOFTWARE
Refund Policy
We provide a free 30 day trial version of Quick 'n Web Builder, for your convenience to fully evaluate the application in your computing environment.
The try-before-you-buy version allows you to try all features so you decide if this is the right software for you.
If you purchase Quick 'n Easy Web Builder (or extensions etc.), after your credit card or check is approved, an email will be sent to you with the activation key to unlock the software.
Once your license has been activated , there will be no refunds given. We must enforce this policy since it would be impossible for you to return your registered version of our software.
We strongly recommend that all users download, install, and test the fully functional trial versions prior to making a purchase.
Your order only qualifies for a refund if you did not activate the license yet.
This is also mentioned in the license agreement, which is displayed before you activate the license.
