I bought a new computer can I still use the same license?
PLEASE READ THESE MESSAGES IF YOU HAVE PROBLEMS WITH YOUR ORDER OR ACTIVATING THE SOFTWARE
The Quick 'n Easy Web Builder license can be used to activate the software on maximum 3 computers, but of course you can still use the same license when you buy a new computer. Normally you will be able to activate Web Builder on the new computer without any problems, but if you get the error 'This license is already registered on another computer!'
please contact info@pablosoftwaresolutions.com to reset your license.
Make sure you include your order id and the email address you used to purchased the software.
Related topic:
http://www.quickandeasywebbuilder.com/f ... php?t=2148
