Free Quick 'n Easy WB 4 template: Grids
filmphotog
Post by filmphotog » Wed Jun 15, 2016 5:02 am
Free Quick 'n Easy Web Builder 4 template: Grids
I made a simple template for the QnEWB. Perhaps someone is interested in using this template as a start and continue to modify the pages.
Terms of use: Free
Extensions needed: None
No licensed images were used.
Responsive Web Design
- Layout Grids
- Panel Menu
- Blog
- Slideshow
- Contact form
- Two pages (four with success and error pages)
Fully functional demo
Template for download
Hope this template is useful, thanks.
Re: Free Quick 'n Easy WB 4 template: Grids
Post by Pablo » Wed Jun 15, 2016 6:00 am
Great work! Thanks for sharing!
filmphotog
Post by filmphotog » Fri Jun 24, 2016 7:39 am
Thanks for the comments!
Post by mexman » Mon Jul 04, 2016 2:18 am
Does not install well on my system (Ubuntu).
Looking into the asset mgr. ist seems that a file is related to specific local locations (C:\users\j\Quick'n Easy Web Builder\grid\icon.png
I do not have that folder....
filmphotog
Post by filmphotog » Mon Jul 04, 2016 3:11 am
mexman wrote:Does not install well on my system (Ubuntu).
Hi, are you able to install without the png? It's the icon for the panel menu and it's here in the published demo. I have contacted support about this.
Thanks.
Post by mexman » Mon Jul 04, 2016 12:53 pm
filmphotog wrote:Hi, are you able to install without the png? It's the icon for the panel menu and it's here in the published demo. I have contacted support about this.
Thanks.
Yes, install is working, but the icon is not installed or not in the right place.
