How do I copy preferences from a previous version?
Each version of Quick 'n Easy Web Builder has its own configuration and publish settings.
However you can copy settings from another version.
Warning: This requires some system knowledge!
Do not copy binary data from the configuration file to the new version because this may corrupt the configuration!
LINUX
Linux stores preferences in a (hidden) file:
/home/yourname/.Quick 'n Easy Web Builder 11
(note that this file is hidden so you will need to make it visible first)
MACOS
Mac stores preferences in:
/User/Library/Application Support/Quick 'n Easy Web Builder 11/Quick 'n Easy Web Builder 11 Preferences
for the Apple App Store version (sandboxed) the system uses:
/User/Library/Containers/com.pablosoftwaresolutions.quickandeasywebbuilder11/Data/Library/Application Support/Quick 'n Easy Web Builder 11/Quick 'n Easy Web Builder 11 Preferences
WINDOWS
Windows store preferences in the registry (regedit)
HKEY_CURRENT_USER\SOFTWARE\Pablo Software Solutions\Quick 'n Easy Web Builder 11
For older versions you will need to replace the '11' with the application's version number.
Re: How do I copy preferences from a previous version?
If you only need the publish settings then copy the following sections:
[PublishLocations]
Count=2
[PublishLocation0]
... options ...
[PublishLocation1]
... options ...
etc
