state of checkbox
psaldari
state of checkbox
Post by psaldari » Fri May 10, 2019 8:11 pm
Hello,
If I have checkbox 1 and checkbox 2, how can i get that if I check the checkbox 1 automatically the checkbox 2 are unchecked? (and vice versa)
Paolo
Re: state of checkbox
Post by Pablo » Fri May 10, 2019 8:22 pm
Checkboxes are multiple choice by design.
For single choice use the 'radio button' instead
psaldari
Post by psaldari » Sat May 11, 2019 12:37 pm
OK, I understand.
But in my form there is three editbox. If I select one, automatically my need is to hide the other two.
Anyway I solved this using a combobox.
Now my problem is another one... but I post this in the correct section.
Paolo
