QnEWB spread out of screen
sirco
Post by sirco » Fri Aug 16, 2019 5:47 pm
I noticed that with the brand new version 6.3.0 I can't resize the screen of the QnEWB which spread out of my computer screen!
Hence, it's impossible to work...
I'm using a MacBook Pro 13 inch, 2016, and running MacOS Mojave.
Any solutionn welcome!
Pascal
Re: QnEWB spread out of screen
Post by Pablo » Fri Aug 16, 2019 8:27 pm
This behavior has not changed in the lastest update.
Windows rezing is a standard system functionality.
If the window size is larger than the screen then you can use the mouse on the border of the main window to resize it. This works the same as with other applications.
sirco
Post by sirco » Sun Oct 27, 2019 5:32 pm
Thks for the advice, which I've already tried before posting...
The problem is the following:
1. QnEW window spread out of screen, but only at the bottom of the screen
2. QnEW window remains sticked on the upper left corner of the screen. I can't move the window on the screen.
Am I the only one experiencing this behaviour? It only occured since the new version 7.
Pascal
Post by Pablo » Mon Oct 28, 2019 6:58 am
You can resize the application window with the 'zoom' button.
Maybe this will be helpful?
https://www.lifewire.com/resizing-macs- ... ks-2259806
sirco
Post by sirco » Mon Jan 13, 2020 9:22 am
Thks for the help.
In fact, I've been able to resolve this problem in the following way:
1. I launch Q&E with full screen on
2. Then I'm able to resize its window in the usual manner, i.e. arrows on the right-down corner.
But, the problem remains: once launched, Q&E stick fixed on the upper-left corner and you can't move it. Except by asking full screen on! Strange in fact...
have a nice day.
Pascal
