Quick 'n Easy Web Builder 7.1.0 update
What's new in 7.1.0?
- Fixed: Flex container ignores right padding.
- Fixed: Missing icon font reference in global style sheet.
- Fixed: Active and hover colors of Breadcrumb switched.
- New feature: FTP now uses use new FTP engine for better performance and stability.
- New feature: Added 'Allow full-screen' option to Inline Frame object. Enables content in an inline frame to be displayed in full-screen mode.
- New feature: Added the ability to target objects on master/embedded pages in Events.
- New feature: Added the ability to change the text of Wizard buttons (Previous, Next, Finish)
- New feature: Added Shape Divider support to Page Header and Page Footer.
- New feature: Added events support to 'Horizontal Line' object.
- New feature: Added 'Full width' option to 'Horizontal Line' object. When set to false, the line can have a fixed width (instead of 100%).
- New feature: Added 'Cookie Expire Days' property to Toast. Specifies the maximum age in days for the cookie to remember the visibility state of the Toast.
The update will also be available in the Mac App Store. This may take a few days depending on how quickly the Apple Review Team accepts the update.
