New extensions: Animated Image Cube, Easy Pie Chart, highlight.js and more!
Here are another 10 new extensions for Quick 'n Easy Web Builder!
All extensions were ported from WYSIWYG Web Builder (https://www.wysiwygwebbuilder.com)
Animated Image Cube
This extension implements an animated 3d cube with images using CSS only. The cube is responsive and can be used in flexible layouts and fixed layout with breakpoints. Each face of the cube can have a different image. On mouse over, the cube faces will expand/explode.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=210
Animated Text Cube
This extension implements an animated 3d cube with text using CSS only (no JavaScript). The cube is responsive and can be used in flexible layouts and fixed layout with breakpoints. Each face of the cube can have different text. It’s also possible to set a link. On mouse over, the cube faces will expand/explode.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=211
Cube Slideshow
This extension implements an experimental 3D cube slideshow using CSS only (no JavaScript).
Each side of the cube can have a different image. It also supports opacity to create nice transparency effects.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=212
Easy Pie Chart
Render simple, animated pie charts. Based on a script by Robert Fleischmann.
https://github.com/rendro/easy-pie-chart
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=213
highlight.js
highlight.js is a popular client-side syntax highlighter that supports a broad range of languages: https://highlightjs.org/
This extension makes it easy to add highlight.js to your website, it supports many themes and includes support for most common languages (html, css, javascript, cpp, php etc).
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=214
prism.js
Prism is a lightweight, extensible syntax highlighter, built with modern web standards in mind. This extension has support for the following languages: applescript, c, coffeescript, cpp, cs, csharp, css, html, java, javascript, perl, php, python, ruby, sass, scss, sql, svg, swift, xml.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=215
Nine Images Gallery
This experimental extension implements a simple (responsive) image gallery with nine images. It uses CSS only, no JavaScript. When an image is clicked, it will expand to the full size of the gallery.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=216
Scroll Button
‘Scroll Button’ is an animated mouse scroll indicator. This can be used to add a subtle scroll cue at the bottom of the initial page that lets visitors know that they can scroll to see more content.
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=217
Twenty Twenty
Showcase the visual differences between two images with a before and after image. Based on a script by Zurb.
https://github.com/zurb/twentytwenty
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=218
Zoom Scroller
Create a subtle zoom animation on images while scrolling. Based on a script by Pete R. https://github.com/peachananr/zoom-scroller
More information:
https://www.quickandeasywebbuilder.com/ ... ile_id=219
You can download the new extensions through the Extension Manager (Menu->Tools->Extension Manager->Online Gallery).
or here
http://extensions.quickandeasywebbuilder.com/
Please read the included PDF documentation for instructions, license information, etc.
