Quick 'n Easy Web Builder 10.1.0 update
*** Current version: Quick 'n Easy Web Builder 11.3.0 ***
This is the first major update for Quick 'n Easy Web Builder 10. This version fixes known problems, adds new features and other improvements.
What's new?
- New feature: Added text alignment property to Select/Combobox.
- New feature: Added support for box shadow to YouTube, Vimeo and HTML video.
- New feature: Added 20 polymorphic shapes (blobs) to the Shape object.
- Improved: Form email list (via combobox) can now also be used in nested layout grids.
- Improved: Responsive font-size for Horizontal Line.
- Improved: Updated plyr.js to version 3.7.8
- Improved: Added Formspree form template. Removed www.formbuddy.com and www.mailmyform.com form templates, because these services no longer exists.
- Improved: Workaround for Lighthouse "Skipped heading level" message in News Feed Ticker.
- Improved: The handling of font weights in Google Fonts has been updated for styles.
- Improved: Card Container no longer uses jQuery for coverflow, stack, cube and flip. The scripts have been redesigned to use standard JavaScript only, resulting in smaller output.
- Fixed: Issue with bcrypt password verification of Login admin.
- Fixed: Issue with button alignment property in Dialog.
- Fixed: Issue with flex container margin in floating layout.
- Fixed: Issue with border radius in Sections.
- Fixed: Issue with File Upload button border-radius.
The update is also available in the Mac App Store.
Quick 'n Easy Web Builder 10.1.1 update
What's new in 10.1.1?
- Fixed: Issue with CSS of Thememable button in breakpoints.
