Quick 'n Easy Web Builder 11.1 update
This is the first major update for Quick 'n Easy Web Builder 11. This version fixes known problems, adds new features and other improvements.
What's new?
- New feature: Added the ability to use a larger font for the User Interface on MacOS: Preferences -> Miscellaneous -> User Interface
- New feature: Added 'HTML' email format to auto responder in form script. Select 'HTML' to insert your own HTML code for the message (for advanced users!).
- New feature: Added 'Include form data in message' option to auto responder form script. This specifies whether to include form data in Auto Response message of the form processor.
- Improved: Media Player now uses 'cover' to fill the entire element when it has a border radius.
- Improved: Implemented workaround for missing icon fonts to make sure the generated CSS is valid.
- Improved: The "Checkbox unchecked workaround" of the Form Processor script now works also in nested Layout Grids (and other containers).
- Improved: When using SunEditor in the CMS, it now automatically saves the data from the editor.
- Fixed: Issue with Photo Collage 'none' effect.
