Quick 'n Easy Web Builder 11.3 update
This update fixes known problems, adds new features and includes other improvements.
What's new?
- Improved: Added 'gpt-4o' text model to dropdown list in Options -> Artificial Intelligence. Also, 'gpt-4o' is now the default model or new installations.
- Improved: AI Vision now uses "gpt-4o" instead of "gpt-4-vision-preview".
- Improved: Timing issues with rollover animations (blast, blocks, rain, swirl and squares).
- Improved: Upgraded to Font Awesome Free 6.5.2 with 18 new icons. Including: bluesky, jxl, upworks, web-awesome, webflow, brave, letterboxd, mintbit, opensuse, pixiv, google-scholar, shoelace.
- Improved: Global Replace now also includes the 'name' property of form elements when replacing text.
- Improved: SEO Assistant also detects headings in cards.
- Improved: Added support for Paddle v2 accounts (Paddle Billing). Currently, there are two types of Paddle Accounts: Paddle Classic (old accounts) and Paddle Billing (new accounts).
To support new accounts, QWB now also accepts a client-side token in Tools -> Options -> Ecommerce -> Paddle Vendor ID. When you specify a token, then QWB will automatically use the new Paddle API v2.
- Improved: Implemented disabled state styling for Themeable Button when published as CSS (opacity:0.6;pointer-events:none).
- Improved: Enable/disable events automatically detects the type of Themeable Button (jQuery UI or Native CSS).
- Improved: Simplified generated code for auto responder in forms.
- Improved: Implemented responsive gap for Card Container carousel mode (OWL).
- Improved: When cloning a folder in the Site Manager, the child pages and sub folders keep their original name.
- Fixed: Issue with Shape/ClipArt/TextArt sub path animation.
- Fixed: Issue with empty rel attribute in text.
- Fixed: Issue with Shape -> Flow Chart Alternate Process and CSS output.
