How do I remove the 'Built With' logo from a page?
In order to be able to remove the 'Built With' logo from a page, you will need to activate the software first:
http://www.quickandeasywebbuilder.com/f ... php?t=1808
Once you have activated the software you can remove the logo from your pages by following these instructions:
1) Select the logo on the page
2) Press the 'Delete' key on your keyboard
Q: But I can't find the logo on my page!
A: In some cases you may have 'hidden' the logo behind other objects. In that case please use the Object Manager to locate the object and remove it from there.
Important notes:
You must republish your page to your website so the page is also updated on the server!
If the logo is still displayed then your browser may be caching the old page. In that case, clear your browser's cache or refresh the page a couple of times to update the browser's display.
