Hey,
I am using the same Card object for both regular mode and breakpoint but it looks different on Mobile mode.
please see attached screenshots.
Desktop:
Mobile:
Why is that happening?
Thanks,
Cards look different on Mobile
Re: Cards look different on Mobile
To be able to help I need the project file so I can see all your settings.
http://quickandeasywebbuilder.com/forum ... 10&t=45024
Yeah sure.
The properties for the card items are different in the breakpoint.
Note that each breakpoint can have its own padding/margin. So, if you want them to be the same then please change them in all breakpoints.
Thanks, i had no idea they are not synced.
Hey Pablo,
Sorry for opening this thread again but I have a question.
I have this card here: http://www.couponsexplorer.com/index.html (the iHerb one)
Is there a way to give the View Code Button the width of more than 100 pixels padding for both left and right? I want the View Code Button to look the same as rest of buttons but because the text is shorter I am limited. How can I do that?
Thank you!
Thank you!
I don't think using a large padding will be the best solution.
To create a full width button, set the left and right value of the padding to: -1
Thanks I will use it together with the Card padding.
I was wondering why when the mouse is over the text: View Code - the mouse is not on default CSS but it recognises it as Text Selector. Is it possible to change that?
Thanks!
If there is no link then the browser will display the standard cursor.
You can set the link to '#', to change this behavior.
