Images disappearing
DoctorWeb
Images disappearing
Post by DoctorWeb »
My sites are all built in version 6, and having updated to version 7, I opened up two qwb files to make some minor changes.
The Preview page shows some images being missing. I have checked and they are there in the folder (all images together in each site's folder). The images appear in the Main ("making up board", not sure what this is called) pane that I make up the pages in, they look fine, but in Preview, some of them have just disappeared.
When I try PUBLISH, the same 'gaps' are evident, where the images should be.
Is this a straight forward problem to solve?
Many thanks
Re: Images disappearing
Maybe you have moved the project, but have not included the project folder with the images?
Or maybe the new version does not have access to the folder? For example, if you use the sandboxed (Mac) version then access is restricted by the system.
You can update the path of the images with the Asset Manager. Make sure the images are in a folder that is accessible by the application.
DoctorWeb
Post by DoctorWeb »
Solved it now, it was connected to moving folders, but one of them had lost its permissions and was refusing to let my machine access or alter the contents in any way.
Thanks for your help.
