Vimeo embed code not valid
makenote3
Post by makenote3 »
Hi, when I try to preview a page with a Vimeo object, I get the message "oops the embed code for this object is not valid".
The link is correct and works if I paste it into any browser:
https://vimeo.com/355905586/5eeddb5d85
Here's how it looks when published:
http://choruswebhosting.com/mediamaze.c ... index.html
The video is "unlisted" and I've tried changing the permissions to "anyone" but still get this message.
I'm using QEWB version 7.2.2 paid
Re: Vimeo embed code not valid
In the properties you should not include the full URL, but only the ID of the video.
See also the information in the help.
makenote3
Post by makenote3 »
Thanks Pablo, I did read the help but didn't understand. For anyone else having the same problem here's what I found:
1. when you copy the link from Vimeo, you will end up with something like this:
The part you need to use in the Video ID box in QWB Vimeo player is just the number 355905586
2. If you use the Vimeo option to restrict the video to only people with the link, you will end up with something like this:
To make the Vimeo visible on your website (even though it's restricted or 'unlisted' for the general public) with QWB you only need to input the same as example 1. ie 355905586, not the / or the numbers after it.
Hope this clears up the confusion.
