So, I am trying now to use Radio buttons, at first - the following Onclick function
Have a look here : https://ourvilla.net.au/page12.htmlfunction LocationStart(buttonid)
var bid = buttonid;
if(bid.name == "My Location")
document.getElementById("RadioButton1").checked = false;
document.getElementById("RadioButton2").checked = true;
else
The one on the left is RadioButton1 which is enabled at first.
I want to have it so that if the user clicks on Button2, it will switch OFF / Clear Button1 (which it does) and Check ON Button2 - which it does not, why?
In the WB system, I was able to group the two buttons, so that if one is turned off, the other comes ON
How do I do it here?
