Parallax Video Background
huckie559
Post by huckie559 »
Hello everyone,
Do any of you know if there's a tool that allows you to use an mp4 video configured as a parallax background ?
Thanks.
Re: Parallax Video Background
The built-in YouTube and Vimeo objects can be set to 'Fill Entire Browser Window', this will set it as fixed background.
huckie559
Post by huckie559 »
Ok. Thanks
I have setup a full screen video clip, works ok, using the HTML5 video object.
Have a look here: www.squadron-125.org.il/home.html
I don't like the idea of needing YouTube or Vimeo.
