cube transition for carousel
reinecath
Post by reinecath »
Hi, I saw that version 8 included new additional transitions (e.g., cube), but "cube" is not listed as one of the animation effects in the property inspector for the carousel object. I want to create a rotating cube that has a different image on each face. Can you point me in the right direction? Thanks
Re: cube transition for carousel
All new animations are available for the 'flexible' carousel, so you will have to set the 'full width' property to 'flexible'.
Demo:
https://quickandeasywebbuilder.com/supp ... tions.html
reinecath
Post by reinecath »
Thanks! That seemed to work.
