Slideshow
Slideshow
All the objects I tried in QEWB have the same interface to add pictures to the show.
I have a story that has 106 pictures, it is very time consuming to have to add each of them one by one
Is there anyone of the slide shows that allows getting all the 106 images in one action?
If so, which one is it?
Re: Slideshow
You can hold the SHIFT key while clicking the 'Add' button. This will open a different dialog where you can select multiple images.
Re: Slideshow
I had no idea... This works fine
Is that documented somewhere?
Re: Slideshow
It is not documented in QWB, but it works the same as in WWB.
Re: Slideshow
Thank you
