FlexContainer parallax background on IOS
michling
Post by michling »
The parallax effect does not seem to be working on my iPhone that is using IOS 14.4.2
I do have the Use Safari mobil background fix set to true.
I am running QEB version 8.1.1
Here is a sample page:
https://mespn.com/dev1Gyrotonic/
Thank you
Re: FlexContainer parallax background on IOS
This is expected behavior. Unfortunately, Parallax does not work on mobile devices. Parallax is a combination of "background-attachment: fixed" an "background-size: cover"
See also known issues:
https://caniuse.com/background-attachment
michling
Post by michling »
Pablo,
After updating to IOS 4.6, it seems that Parallax is now working as you can see on this website, using an iPhone running IOS 4.6 or later.
https://posturecompanystudio.com
Thanks...
Cool!
