Slideshow
Slideshow
Please have a look at this link : http://nmaa-rc.org.au/newsite.html
It has a slideshow set as Conveyer Belt.
Is it possible to have a picture that opens up in a lightbox when the visitor clicks it?
When I tried to invoke an Event, it has now a whole list of Activate(1)... What is this, We used to have Onclick....
If so, how?
Alex
Re: Slideshow
I'm sorry, there is currently no standard solution for this this.
But you can add custom or third party scripts via the HTML object.
Or else use a static photo gallery, which does support lightboxes.
Re: Slideshow
What do you mean, static photo gallery?
Which object should I try?
In my current setup what is - Activate(1), Activate(2).... in Events?
Re: Slideshow
