strange problem on mobile phone
Please have a look at this page : http://nmaa-rc.org.au/fp21.php
I have set a break point at various sizes : 480, 400, 360
In all cases, the screen can be scrolled sideways insteading of being fixed on screen
What am I doing wrong?
Re: strange problem on mobile phone
It looks related to the custom code you have added via "Html1"
I think the type should be set to "Between <head> tags"
That is not resolving it, I found out the problem
http://nmaa-rc.org.au/Screenshot_wrong.jpg
http://nmaa-rc.org.au/Screenshot_right.jpg
If the Modal dialog is outside the break point, it will do that.
In my mind there is a bug somewhere
In your example, the HTML1 object is outside the viewport. That is why there is a scrollbar.
All objects should be inside the viewport.
Well, it seems this rule doesn't always work:
1) In the default viewport, it is outside the viewport and it works fine
2) IN breakpoint 480px, it is inside the viewport and it works fine
3) in breakpoint 700px, it is inside the viewport but it doesn't
So?
If the object is placed outside the viewport, then this will affect the page size.
That is why the browser adds a scrollbar.
Positions and sizes are responsive so they need to be set for each breakpoint.
OK, now I got it
All good
