Give visitor page edit access
Re: Give visitor page edit access
You did not enable font-size button on the toolbar of summernote. So, that is why the table has a 'random' font.
You can use the 'Editor settings' properties to customize the toolbar:
https://summernote.org/deep-dive/#customization
Or you can switch to 'HTML' mode (in the summernote) and set the fontsize manually.
The table does not have a border. The outlines in the editor are just there to help you see where the cells are.
Note that this is related to how the summernote editor works, not to QWB.
I did not create summernote myself, so I have no control how it works. But I think it's very powerful so that is why it's one of the supported editors.
Dear teacher,
I know it is NOT a WB issue and 3rd party tools are provided AS-IS.
But, maybe you can instruct me : https://nmaa-rc.org.au/adminedit.jpg
See the difference in that image between how it looks in the editor compared to the html result.
What is all the EMPTY white space on the right, in design mode in WB I don't have it
what can I do to fix that?
Thanks again
The editor can only edit the content, not the 'container' of the object.
There is white space because the table is not set 100%.
You will need to enable the 'html' button of summernote to change this.
OK, I went through the documentation, how do I enable the html button? Can't figure it out.
Something like this:
  toolbar: [
     ['view', ['fullscreen', 'codeview', 'help']]
OK, I added it and when I view the html code, all I see is this:
<table style="font-family:Arial;font-size:13px;color:#000000;" class="table table-bordered"><tbody><tr><td><b style="">Membership</b></td><td><b>MAAA</b></td><td><b>VMAA</b></td><td><b>NMAA</b></td><td><b>Total Fee</b></td><td><b>Associate</b></td></tr><tr><td><b>Senior</b></td><td style="text-align: right; ">$190.00</td><td style="text-align: right;">$39.00</td><td style="text-align: right;">$110.00</td><td style="text-align: right;">$239.00</td><td style="text-align: right;">$110.00</td></tr><tr><td><b>Pensioner</b></td><td style="text-align: right; ">$90.00</td><td style="text-align: right;">$39.00</td><td style="text-align: right;">$80.00</td><td style="text-align: right;">$209.00</td><td style="text-align: right;">$80.00</td></tr><tr><td><b>Junior</b></td><td style="text-align: right; ">$45.00</td><td style="text-align: right;">$12.00</td><td style="text-align: right;">$20.00</td><td style="text-align: right;">$77.00</td><td style="text-align: right;">$20.00</td></tr><tr><td><b>Non-Flying</b></td><td><br></td><td><br></td><td align="right"></td><td style="text-align: right; ">$20.00</td><td style="text-align: right;">xxxx</td></tr></tbody></table><div style="font-family:Arial;font-size:13px;color:#000000;"><div style="text-align: right;"><br></div>
</div>
How do I set the table to 100%?
Thanks again
Add "width:100%" to the style section of table.
OK, this works now fine.
But something stranage : https://nmaa-rc.org.au/memberfees.html
The editor shows a setup for line height, but I can't figure out how to use it, to space out the rows
To add spacing between the rows you can use padding.
This also require changes to the HTML.
If so, what is the "T" button in the editor?
Any hint on how to add padding in the html?
There is no dedicated option for this in SummerNote.
You will need to add the padding via the HTML view of the editor.
https://www.w3resource.com/html/attribu ... ribute.php
It seems however that it effects both , horizontal between cells and vertical between lines.
I only want to do it between lines, any other way?
In that case, you will need to use CSS padding.
For example:
style="padding:10px 0 10px 0"
Please note that I cannot give support of coding. This is not specific to QWB.
Yes, that should work
Thanks again
I created a new page, password is password
https://nmaa-rc.org.au/adminedit21.php
But, when I save the page, only a .json file is generated, not a html page
How can I fix this?
