Malwarebytes
davidmuncaster
Malwarebytes
Post by davidmuncaster »
I've just used QNEWB8 for the first time and when I went to publish the site Malwarebytes closed the programme saying that there was malware in the exe file. I had to disable Malwarebytles in order to publish my site. I never had a problem with QNEWB5 so don't know if it is an issue with the version or with a Malwarebytes update.
Re: Malwarebytes
There is no virus or malware in the software. This is a false positive.
To solve the problem, add the software to the exception list or contact the makers of Malwarebytes for an update,.
