How work flex box as a form?
posgross
Post by posgross »
I create flex box with field inside the layout grid
http://joxi.ru/Vm6ddQ4F4MPkwA
Then I wan to sen data from field, add Button, but I see some ERROR
http://joxi.ru/82355kvI9Rdj9r
I don't find detailed instructions on forum
Re: How work flex box as a form?
Flexbox and layout grids are two different layout methods, they should not be nested into each other.
I recommend to use a nested layout grid instead.
posgross
Post by posgross »
Pablo wrote: Sun Dec 26, 2021 8:45 am Flexbox and layout grids are two different layout methods, they should not be nested into each other.
Thanks I'll try
Can you show some example
There are many examples available here:
https://wysiwygwebbuilder.com/templates2020.html
