Card Container
Card Container
Hello,
I would like to use the card container feature in my website but I don't understand why it always stick to the top of the page. What if I would like to place it in a specific fixed position, is this possible?
Thank you.
Re: Card Container
A card container, is a floating layout container. Just like a layout grid, and a flex container, otherwise it cannot be flexible.
To learn more about layout modes, please see this tutorial:
https://www.quickandeasywebbuilder.com/ ... modes.html
Re: Card Container
So it means I must update my whole page to use layouts.
Is there any alternative solution? I would like to use the carousel card container and I don't want to migrate my whole website to layouts now.
Thank you.
Re: Card Container
Correct, you will have to use flexible layout for the entire page otherwise (fixed/absolute) elements will overlap.
Re: Card Container
Is there maybe any template you created which use layers with a combination of Card Container by any chance?
Re: Card Container
