Moving from macOS to Windows
Hello,
I might need to work on my project from Windows as well, is there anything that should be done for the project that was built on macOS to work on Windows operating system?
Thank you.
Re: Moving from macOS to Windows
Just copy all project files (qwb and project folder) to the Windows computer.
