How to create a new website from a template
Edward2022
Post by Edward2022 »
I am running QNEWB 9 and want to create a new website from the following page, the site in the top left-hand corner.
http://www.quickandeasywebbuilder.com/t ... s2022.html
See also https://www.quickandeasywebbuilder.com/ ... tml#stores
I have downloaded the files, which are in a zipped folder called author, and have unzipped the files. I can't find a way of creating a new website using the author.qwbt file. Help!
Re: How to create a new website from a template
Edward2022
Yes, that fixed the problem. Although I had read that page previously, I hadn't understood what I needed to do. I had to manually copy the author.qwbt template file to my C:\Users\Lenovo\Documents\Quick 'n Easy Web Builder\templates folder. Thank you for your help.
EDIT: I also had to copy the author.jpg file too.
