Why even if I have objects underneath, the browser stops and doesn't let me see them, at the same time that I can't work from that point?
Best regards.
Antonio F.S.
https://drive.google.com/file/d/1VenHGn ... sp=sharing
The browser is not working any more.
Re: The browser is not working any more.
Hello.
I assumed that the false value of the automatic page size would enlarge the page as needed, but it wasn't being so. It turns out that I have removed the automatic mode and set the height to 10000, and now I can see and work as I add objects. I don't know if this could be a bug.
Best regards.
Antonio F.S.
https://drive.google.com/file/d/19EPQqX ... sp=sharing
Best regards.
Antonio F.S.
To be able to help you, I need a DEMO project (.qwb file) so I can see all your settings.
I do not need the complete project because that will only take more time to figure out what you have done.
Basically, I just need a small project with one page and object(s) that are relevant to your question.
Note that I cannot see what you have done based on a screenshot, because the software has thousands of options and millions of possible combinations.
So, there is no way to know which combination of options you have used
For further details about how to share a project file, please see this FAQ:
viewtopic.php?f=10&t=45024
Hello
Here I send you a part of the project in which you can verify the problem that I have raised. I also attach the link to a small sample video for you to see it better.
https://drive.google.com/file/d/1an7oow ... sp=sharing
https://drive.google.com/file/d/1_S5exc ... sp=sharing
Thank you.
Antonio F.S.
Thank you.
Antonio F.S.
To increase the height of the page:
- set the height manually in the page properties
- drag the handle at the bottom of the vertical ruler.
- with "automatic page size" set to "true", drag an object to the end of the page, this will automatically increase the size
Note that this only affects the size of the workspace.
The actual height of the page in the browser is determined by the content on the page.
Hello.
Great. Thank you very much Pablo.
Since you have the example project I sent you, how can I add a layout grid in a desired position? It always goes to the end.
Thanks again.
Antonio F.S.
Thanks again.
Antonio F.S.
You can use the Arrange tools to re-arrange layout grids (move forward, move back, etc).
Or if your keyboard has numpad keys then use '+' or '-'
You can also use re-arrange layout grids (and other objects) via the Object Manager.
Hello.
It was right in front of my eyes and I didn't notice it.
Very satisfied with the after sales support. Thank you very much
Best regards.
Antonio F.S.
Best regards.
Antonio F.S.
