Header color upon scroll
Wombat66
Post by Wombat66 »
Hello experts,
I need help with changing a Header.
From a qwb6 template, snowworld.qwb, the header starts off as transparent. As soon as I start to scroll down, the header background changes to a solid blue. Where can I change that blue, to a different color? I’m using Quick ’n Easy Web Builder 9.3.1 (Mac App Store version) but cannot determine where that setting can be modified.
Re: Header color upon scroll
This behavior is defined in the HTML object: Html1
#wb_header.affix
   background: #FF0000;
Wombat66
Post by Wombat66 »
Perfect!
Thank you so much!
