Breakpoint count
VSH
Breakpoint count
Post by VSH »
Hello, i create a site with 50 breakpoints per page(20 pages) and everything seems alright,but help file says: "Of course, you can define your own widths and have as many breakpoints as you like (max25)....".
I wold like to ask you can this cause any problems?
Re: Breakpoint count
50 breakpoints? That is way too much!
Normally a website has 2 or 3 breakpoints. (Desktop/default view, tablet and mobile)
In general, you only add a breakpoint when the layout 'breaks'.
VSH
Post by VSH »
I want to prevent horizontal scrolling as much as possible for different device resolutions.
for example: i have breakpoint 412 but visitor device have resolution 400,than to see all content, left and right scrolling is needed.This can be seen in firefox ctrl+shift+m for my site.
I have been collecting most popular devise resolutions from Google Analytics about 5 months.
50 breakpoints is way to much.
If you use layout grids then you need 3 breakpoints at most. For fixed layout maybe 4.
I strongly recommend to rethink your layout. Keep it simple!
VSH
Post by VSH »
Тhanks i will follow the advice :)
