Show Label and Link Logic
I need your expertise with something I would like to create using Quick n Easy Web Builder.
I have a button and a label and I would like that once pressed it'll do the following:
1. Open a link.
2. Show a label (that is set on hide in default).
Is that somehow possible? This logic can be very helpful for my project.
Thank you!
Re: Show Label and Link Logic
You can trigger actions with events.
If I set two events:
1. Show Object.
2. Link.
The link is opened on the same window, can I somehow do it with _blank?
Thanks.
There is no '_blank' option for events.
Link will replace the current URL.
Can I add it as a feature request? According to Google it seems like there is a solution for this using Events.
Using: window.open('https://www.w3schools.com', '_blank');
Thanks.
You can use that code via the 'JavaScript' option in Events.
Perfect, thanks.
