Multiple builders on same website?
Hello all, I haven't seen this question so I will post it here. Can I and another person (with separate licenses of course), edit the same published website using quick 'n easy webbuilder? I have posted the published site to be worked on my server. Can we link the other software which will be on Linux machine to make updates? This software is perfect because they don't know HTML, but I still need to use it because we use a lot of PHP with a MySql database. I want them to be able to make cosmetic updates and I bought this software some months ago to test. It definitely works. So can we do this?
Re: Multiple builders on same website?
You can basically upload your save file and sources to a shared folder like Google Drive or Dropbox and then you both use the same project.
Of course I don't recommend working on the app together in parallel.
No we won't work in parallel. Ok thanks, not the best solution, but I can work with it. Thanks
