Q n E Deb version
uffex
Q n E Deb version
Post by uffex »
Good day folks
For some considerable time I have struggled with an installing issue to the current 64b Zorin OS with Q N E Deb 64 version.
Not until recent days did I discover the cause of the problem which manifested in the following way. I would download the current version of Q n E, click on it to install which appeared to have loaded, however launching the software would not show up in the applications folder.
The statement read that the software was resident in the OS each time I tried to re-install even after purging the residue of Q n E.
For another reason I formatted the drive and made a new Zorin installation, first software was the Q n E which loaded and launched without any hitch.
My conclusion is that Zorin will keep a element of third party Deb installation which prevents new functioning. My thread is to maybe help some other users going through the same turmoil.
