How to install Quick 'n Easy Web Builder on Linux?
There is currently no installer for the Linux version. Just extract all to a folder of your choice.
1) Unzip all files to a folder of your choice.
2) Double click qnewb (executable)
If the software does not start then your system may be missing the following package:
Microsoft TrueType Core Fonts
These fonts are a requirement because they are basis for all websites (so called web safe fonts, see also the manual).
To install them, open up your Synaptic Package Manager (System -> Administration -> Synaptic Package Manager). Search for 'Microsoft core fonts'.
Check the box beside it and select Mark for Installation. Click Apply at the menubar to install the fonts package.
If you are running a 64 bits version of Linux then you should also install 'ia32-libs' and/or the 'libgtk2.0-0:i386' package.
To install the libgtk2.0-0:i386 package please use:
sudo apt-get install libgtk2.0-0:i386
in a terminal session.
More details:
http://packages.ubuntu.com/lucid/libgtk2.0-common
Re: How to install Quick 'n Easy Web Builder on Linux?
On 64 bits systems you may also need the following packages:
apt-get install libstdc++6:i386
apt-get install libsm6:i386
or
sudo dpkg --add-architecture i386
Run Quick 'n Easy Web Builder on Fedora:
sudo yum install libpng12.so.0
sudo yum install cabextract
sudo rpm -i http://sourceforge.net/projects/mscorefonts2/files/rpms/msttcore-fonts-installer-2.2-1.noarch.rpm
'libpng12.so.0' is required for the graphics
'cabextract' is required to be able to run 'rpm'
'msttcore-fonts-installer-2.2-1.noarch.rpm' installs web safe fonts.
For Debian/Ubuntu based versions of Linux you can now download a .deb package:
http://quickandeasywebbuilder.com/download.html
Installation:
sudo dpkg --install quick-n-easy-web-builder-2_x.x.x_i386.deb
where x.x.x is the version number.
The application will be installed in the Applications folder (usr/share/applications)
If you get the following message...
./qnewb: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
... then try these commands:
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_amd64.deb
or
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_i386.deb
