My forum account is no longer available. What has happened?
On this forum you can find lots of information about Quick 'n Easy Web Builder, you can ask questions, post suggestions or get in contact with other users of the software.
*** FORUM RULES ***
Before you post anything, make sure you have read the forum rules:
https://www.quickandeasywebbuilder.com/forum/viewtopic.php?f=12&t=1901
*** HOW TO CREATE A NEW TOPIC? ***
This article explains how to create a new topic on this forum.
https://www.quickandeasywebbuilder.com/forum/viewtopic.php?f=10&t=46386
*** NEED HELP? THEN PLEASE SHARE A DEMO PROJECT! ***
Quick 'n Easy Web Builder has thousands of options and millions of possible combinations, so to be able to help you we need to know exactly which combination of options you have used.
For further details about how to share a project file, please see this FAQ:
https://www.quickandeasywebbuilder.com/forum/viewtopic.php?f=10&t=45024
As part of our ongoing system maintenance, from time to time we disable or remove accounts that are no longer active. Accounts that have not accessed the forum for more than 6 months are considered inactive and are subject to being deleted. Note that we do not delete accounts if there are still activate posts associated with that account. Unless those posts have become obsolete (because they apply to older/unsupported versions of the software).
If your account was removed then you can re-create that account to join the forum again:
http://www.quickandeasywebbuilder.com/f ... =12&t=7793
Re: My forum account is no longer available. What has happen
Another reason for disabling an account is if you have violated the forum rules. Although usually we only do this in very extreme cases.
You can read the forum rules here:
