Quick 'n Easy Web Builder 2.2 update
*** Current version: Quick 'n Easy Web Builder 13.0.0 ***
Quick 'n Easy Web Builder 2.2 fixes known problems, adds new features and includes other improvements.
What's new in 2.2?
- Improved: Linked files in navigation menus and links are now also visible (and editable) in the Asset Manager.
- New feature: Added the ability to configure a document folder for the sandboxed edition of the Mac version. This will give the application full access to that folder outside the sandbox container!
You can set the folder in Preferences->Miscellaneous->Sandbox folder.
- New feature: Links can open in a (fancybox) lightbox with the target option. You can also set options to customize the lightbox appearance.
- New feature: Added lightbox support to inline frame, html5 video/audio, vimeo and youtube.
You can download version 2.2 here:
Re: Quick 'n Easy Web Builder 2.2 update
Update:
There was a bug in version 2.2 that prevented some previously saved projects from opening.
The problem should be fixed in version 2.2.1.
