The home page it is positioned in the footer
cch
Post by cch »
When I loading the home page it is positioned in the footer and not on the Top page, what is the problem? I used the Dividers template, can you help me? My website is http://adreamup.com
Re: The home page it is positioned in the footer
I'm not sure, but I think is is related 'autofocus' property of the form button.
The default is 'false'
cch
Post by cch »
Thanks Pablo for your reply,
I have the 'autofocus' property on 'false' in the form properties.
I rename the page, create another one as index.html and copy all the contents. The problem is solved.
Best regards,
Carles Chetrit
