Inserting a php page from an external file
I have a page on the server and noticed it missing from the project.
I tried inserting it from and External file (I downloaded it to my computer) but it ends up inserting a different page, I tried several time but it keeps inserting instead the index.php of that same project
Hope you can give me a hint...
Re: Inserting a php page from an external file
Using "external file" in the Site Manager should work.
What exactly do you means by?
Are you sure you have selected the correct file?
I have 3 files on my pc desktop.
I icky the one I want, but it inserts the fileme I selected, but the content of another file.
That is very usually! But maybe you have already used the same name for another page?
No, I have not.
But if I did, how will it insert the same name again?
It works for me, so I need more details.
Please share the project file, the file you are trying to insert and describe the exact steps to reproduce this behavior.
Here is the project file, just empty - started it for sending to you
https://squadron-125.org.il/fileInsert.qwb
And the file I am trying to insert
https://squadron-125.org.il/loginfail4pablo.php - it seems that the index.php code is embeded inside this file???? It launches the website itself....
Do you mean that you are trying to embed a file on the server?
That is not possible it must be a local file (on your local disk). PHP code only exists on the server.
Well, I removed the PHP segment, changed the file name to .html and tried to insert it agian into the project, the following is all that was imported from the entire file.
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Untitled Page</title>
<meta name="generator" content="Quick and Easy Web Builder - https://www.quickandeasywebbuilder.com">
<style>
body
background-color: #FFFFFF;
color: #000000;
font-family: Arial;
font-weight: normal;
font-size: 13px;
line-height: 1.1875;
margin: 0;
padding: 0;
</style>
</head>
<body>
</body>
</html>
But the html section is much longer, where is the rest?
Did you insert it as a local file?
Did you mean 'import' or 'insert'? These are two different options.
'Insert external file' will add the file "AS IS". The software will not make any changes to the file.
I used "insert External file", I don't know where is import.
My my package is not ok?
What are the exact steps to reproduce this behavior?
How do you know the wrong file is added? Where do you see this?
I open the project
Position my mmouse cursor on the top HOME icon
Right click, select : Insert External File
It open File Manager, I navigate to the Desktop
I select the html file (I renamed the file and removed the PHP segment
I click the "Open" button at the bottom, should it say maybe "Insert" ?
It inserts the file I selected, BUT
The file appears as a LINK to the file, not the file itself
The content of the link, shows the content of the Index.html in the project, NOT the content I need to insert - the name of the file is login.html
That's what happens at my end
Thaks
Correct, the file will be added as a link.
You cannot open/edit or view the file inside the software. it is just a reference to an external file so you can use it in menu's etc.
But, what about the content, of another page?
