Quick 'n Easy Web Builder 5.2 update
What's new in 5.2?
- Fixed: HTML5 audio in lightbox does not show controls.
- Fixed: Table cells do not support text-align: justify
- Fixed: Duplicated font-weight in styles using Google fonts.
- Fixed: File Upload width issue in breakpoints.
- Fixed: Dashed line-style is solid in breakpoints.
- Fixed: Text has invalid responsive style when used in flexbox.
- Improved: Layers with video background can now also have a different background in breakpoints.
- Improved: Rollover layer now also works in a master frame.
- Improved: og:url (Open Graph Meta Tags) can now include the page name in the URL.
- New feature: Added 'goto' support to the SlideShow which can be used in events (just like the Carousel). Example: $('#SlideShow1').slideshow('goto,2');
- New feature: Added 'equal to (choice)' and 'not equal to (choice)' options to Combobox conditions. This creates unique conditions for the specifies values.
- New feature: Added 'Enable form' to the Carousel. This makes it possible to use the Carousel as a multi page form.
See this tutorial: http://www.quickandeasywebbuilder.com/c ... izard.html
You can download version 5.2 here:
The update will also be available in the Mac App Store (this may take a few hours).
