Quick 'n Easy Web Builder 8.1.0 update
Quick 'n Easy Web Builder 8.1 is a major update. This version fixes known problems, adds new features and other improvements.
What's new?
- Fixed: Issue with 'Indicate current page' in Responsive Menu.
- Fixed: Responsive Menu icon size resets when cloning a page.
- Improved: Upgraded to PHP Mailer version 6.2.0. More details: https://github.com/PHPMailer/PHPMailer/ ... angelog.md
- Improved: Upgraded to plyr 3.6.3 (for use with YouTube, HTML audio/video and Vimeo)\
- New feature: Added 'Accent color' property for Plyr in YouTube, Vimeo and HTML5 Audio/Video. The accent color specifies the primary UI color of the player.
- New feature: Add 'full width' property to Rollover Text for use with Layout Grids.
- New feature: Added the ability to add events to cards.
- New feature: Added support for 'scrollspy' to Overlay Menu.
- New feature: Added support for 'highlight current page' to Overlay Menu.
- New feature: Added 'stretched link' option to cards. If this option is enabled then the full card will be clickable when a link is used in one of the items (for example a linked button).
- New feature: Added 'border-width' property to Mega Menu.
- New feature: Added support for responsive fonts to the Accordion, only for flexible layouts (eg. position children must be 'floating')
- New feature: Added 'full width' property to flexbox container. This option can be useful when the flex container is part of a layout grid.
- New feature: Added the ability to use the same name for a folder and page (in the same folder).
- New feature: Added the ability to use 'Dividers' in a Carousel.
- New feature: The height of Shape Dividers is now responsive, so they can have a different height in breakpoints.
- New feature: Panel menu links now have a seperate alignment property. So, the button and links can have a different alignment.
- New feature: Added 'default' overflow mode to Layout Grid. This new option introduces a new simplified responsive mode for layout grids. In 'default' mode, the number of columns is the same in all breakpionts (like overflow = none) however the column properties (padding, order, alignment, border) are responsive.
The update will also be available in the Mac App Store. This may take a few days depending on how quickly the Apple Review Team accepts the update.
